Unzip multiple archives at once
Posted: 02 Sep 2007, 18:24
by Chris
I would like to unzip multiple zip files at once using the unpack function. I select multiple zips and select copy to other pane, but it only unzips the first of the selected files. Is it not possible to do that? When I use the external Winzip interface it works but I always have to browse to the path instead of being able to use the nice Salamander "unzip to other pane" function.
Posted: 02 Sep 2007, 19:08
It is not possible now. I will move this thread to feature requests.
Re: Unzip multiple archives at once
Posted: 03 Sep 2007, 09:12
by KNUT
Chris wrote:I would like to unzip multiple zip files at once using the unpack function. I select multiple zips and select copy to other pane, but it only unzips the first of the selected files. Is it not possible to do that? When I use the external Winzip interface it works but I always have to browse to the path instead of being able to use the nice Salamander "unzip to other pane" function.
Look here for a workaround with the command line tool Infozip. 8)
