Unzip multiple archives at once
I would like to unzip multiple zip files at once using the unpack function. I select multiple zips and select copy to other pane, but it only unzips the first of the selected files. Is it not possible to do that? When I use the external Winzip interface it works but I always have to browse to the path instead of being able to use the nice Salamander "unzip to other pane" function.
Re: Unzip multiple archives at once
Look here for a workaround with the command line tool Infozip.Chris wrote:I would like to unzip multiple zip files at once using the unpack function. I select multiple zips and select copy to other pane, but it only unzips the first of the selected files. Is it not possible to do that? When I use the external Winzip interface it works but I always have to browse to the path instead of being able to use the nice Salamander "unzip to other pane" function.
Kind regards, KNUT
