odd icon scaling
frax
odd icon scaling
Post by frax »
Hi, AS 2.5 running on Windows Vista Ultimate, 32-bit, with large fonts.
I get some odd problem with the icon scaling, where the icons in the detailed views are rendered differently than in Explorer - and/or how I want them to be.
See screenshot for an example. Any way one can get around this, to display the original (unscaled) 16x16 pixel icons?
example - comparing AS 2.5 and Windows Explorer
Thank you for reporting this problem, I can reproduce it.
Salamander is displaying 16x16 icons while Explorer is scaling icons to match font size (tested on 120DPI font size).
frax
Post by frax »
are you sure that is the case? To me it looks like explorer is displaying crisp 16x16 icons, while AS is trying to scale them... (but I might be wrong)
it is at least not the 16x16 icons that are in the icon file(s) (which I want to display) - but it might be 32x32 icons that are scaled to 16x16.
Copy screenshot to clipboard (PrintScreen), switch to Salamander and display clipboard using command Plugins > PictView > View Bitmap From Clipboard.
Then you can measure rectangle width and height using Select tool.
frax
Post by frax »
yes they are 16x16 in AS, and larger in explorer - but I still think AS scales down the 32x32 icons, instead of using 16x16 (if they are available for the filetype)
