Count Directory's and show it
Guest
Post by Guest »
A new nice feature wouold be, that the information-line shows the number of DIRECTORYS shown above...
Did you know, that if you select some items in a panel, then it's counted in the status bar (files and directories separatedly)?
The fastest way is to press Ctrl+A and that will select all items in the panel and count them for you (in the status bar). If you don't want to lose your previous selection, use Ctrl+Shift+F5 and Ctrl+Shift+F6.
Guest
Post by Guest »
ether wrote:Did you know, that if you select some items in a panel, then it's counted in the status bar (files and directories separatedly)?
It would be very nice to have the option to show the number of files (and yes directories) without having to select anything. It seems a very common thing to be able to want to do and it would be nice if that was an option for the information line.
