Alternative Editor Menu (Edit with...)
Posted: 09 Aug 2007, 12:54
by SvA
There should be the possibility of adding a caption for the menu to each entry in the editors list. Thus the menu could
  • • get tidied up (no path names and executable names, but application names instead)
  • • keyboard shortcuts could be determined by the user (using &-character in caption)
  • • items would be distinguishable.
    How do I know, which menu item I have to select if i want to use pspad editor in text and hex mode? The only difference in calling the two alternatives is in the parameter /H, which does not show up in the menu, so I have two identical lines in the menu.
Posted: 09 Aug 2007, 13:10
Very good idea!
Also applies to Viewers and Alternate Viewers lists.
