There should be the possibility of adding a caption for the menu to each entry in the editors list. Thus the menu could
• get tidied up (no path names and executable names, but application names instead)
• keyboard shortcuts could be determined by the user (using &-character in caption)
• items would be distinguishable.
How do I know, which menu item I have to select if i want to use pspad editor in text and hex mode? The only difference in calling the two alternatives is in the parameter /H, which does not show up in the menu, so I have two identical lines in the menu.
