Checksum plug-in already has recursive directory scanning, but all results are stored in a single checksum file.
I'd like to be able to select a single directory and have Checksum plug-in create one checksum file in each subdirectory (based either on content filenames or directory name), if checksum file is not already there.
Also, does Checksum plug-in have to use modal window for scanning? CRC checksum creation can take quite a while and I cannot continue my work until it's done.
Checksum plug-in: One SFV per directory
- Josip Tosic
Re: Checksum plug-in: One SFV per directory
Starting with the next release of Altap Salamander (2.52), the Calculate window is no longer modal. Thanks for the suggestion!Josip Tosic wrote:Also, does Checksum plug-in have to use modal window for scanning? CRC checksum creation can take quite a while and I cannot continue my work until it's done.
