Quick Rename - Cursor Positioning Option
On the limited occasions that the new style Quick Rename is beneficial to me, most often its use would be to append some text to the existing filename.
As it is now, the new style Quick Rename selects the filename, but the cursor position is positioned on the . (dot).
So in order to rename as I wish, appending text to the filename, I first must right-arrow, then left-arrow, to get to my desired text insertion point.
Suggestion to have option to position the cursor before the (dot). That would allow those who (Can that be done - probably not?)
Or to have the "quick" part either select the filename, as it does now, or to select (dot)extension.
If it was able to select (dot)extension, then it would simply things as only a left-arrow would be needed before text insertion (or pasting).
