Regular Expressions in Filters?
zebranky
Post by zebranky »
Not sure if this has been posted, so apologies if it has.
What I would like to see on the filters/selections is a way to use regular expressions as well as wild cards. As an example, I would like to filter files like so:
FileName_[0-9]+\.zip
This would select files like:
  • FileName_0.zip
    FileName_37.zip
    etc.
But not
  • FileName_a.zip
    FileName_98b.zip
    etc.
The above example is not the best, and there may be a way to specifically do the above already, but regex is so much more than the above.
cincura.net
Post by cincura.net »
:idea:, very good idea.
Jiri {x2} Cincura
Note: [x] Regular expression checkbox would be necessary.
+1 for this.
+1 = My vote
If you were to do something like that, then maybe more generally, it could supersede Operation Masks.
Operation Masks
Some Altap Salamander operations, such as Copy, Move, or Rename, support entering of operation mask. Operation mask is appended behind the target path.
