I was waiting for the full version, but unfortunately it is still not implemented
windows mobile plugin x unpacking archive
nocturne.op.15
I'm working with Windows Mobile devices often - Salamnder plugin is great in this way. But in one detail it is making me mad. That is the case when you have file inside archive in one pane and want to copy it to WM device open in second pane - mipossible, unpacking archive to plugin is not yet supported. I must copy it out from archive to some temporary position and then copy to wm device.
