Remember folder's view settings
rts
Post by rts »
Hello,
I'd like to see the MS Windows Explorer's "Remember each folder's view settings" option implemented in Salamander:
MS Windows Explorer menu -> Tools -> Folder Options ->
-> View -> Advanced Settings:
[x] Remember each folder's view settings
so that different folders can be sorted using different column in detailed view (file name, date/time, size, ...).
I use this feature in Windows Explorer to sort folders containing log/backup files by date/time in descending order to see the most recent logs/backups first / at top, while all other folders are sorted by file name in ascending order (default).
Thank you.
R. Tomis
JohnFredC
Post by JohnFredC »
Support...
Or at least when the tabbed folder interface comes, the tabs themselves should remember sorts and filters.
Mouse-centric, Registered
I find this feature of explorer annoying.
One way I could think of living with was to have a way to make the current sort/pannel display setting permanent for the current folder. I'd suggest to store this information in a file in the folder (similar to (or even using)) desktop.ini. This way, when moving the folder, it's settings would automatically follow.
With custom colums, a way of remembering the display mode most likely will be indispensible.
