Highlighting Problem in Quick Renamer?
Posted: 07 May 2007, 14:05
Hi everyone,
it just came to my attention that there seems to be a problem with the quick rename function. I'll do my best to describe what I found:
If you open a file let's say example.txt it is usually blocked from outside editing, meaning you cannot rename, delete or move it (depending on the application you use. I tried PDF files)! Now if you hit F2 and try to rename it to example123.txt Windows/AS will throw an error message at you, stating that the file cannot be renamed. The problem is, that the highlighted text is exactly as long as the original name was:
False: example123.txt
Correct: example123.txt
Is that meant to happen?? If you have "Select whole name (including extension) in Quick Rename" enabled highlighting works like a charm.
Regards,
Nephilim
P.S.: Nevertheless a marvelous piece of software!!!!
Regards,
Nephilim
