Hi everyone,
it just came to my attention that there seems to be a problem with the quick rename function. I'll do my best to describe what I found:
If you open a file let's say example.txt it is usually blocked from outside editing, meaning you cannot rename, delete or move it (depending on the application you use. I tried PDF files)! Now if you hit F2 and try to rename it to example123.txt Windows/AS will throw an error message at you, stating that the file cannot be renamed. The problem is, that the highlighted text is exactly as long as the original name was:
False: example123.txt
Correct: example123.txt
Is that meant to happen?? If you have "Select whole name (including extension) in Quick Rename" enabled highlighting works like a charm.
Regards,
Nephilim
P.S.: Nevertheless a marvelous piece of software!!!!
Highlighting Problem in Quick Renamer?
I can reproduce it, thank you for the information!
Will be fixed in Salamander 2.51.
Edit: changed version numbers: 2.6 to 2.51, 2.7 to 2.52, and 2.8 to 2.53
