TortoiseSVN icons overlays disapear
Posted: 02 May 2007, 20:30
by anon
All icons overlays dissapear sometime. Salamander restart didn't help. I'm using the latest version of TortoiseSVN.
PS. Interesting fact. If I kill the process tsvncache.exe and restart salamander - it's ok again
Posted: 02 May 2007, 22:39
by Petr Solin
anon wrote:I'm using the latest version of TortoiseSVN.
Are you using nightly build of TortoiseSVN?
What's your Windows version (including 32-bit or 64-bit)?
Does somebody have the same problem with icon overlays?
Posted: 02 May 2007, 23:17
by cincura.net
Petr Solin wrote:Does somebody have the same problem with icon overlays?
Me too. But when this happend, the was no application that shown overlay icons.
From my looking for problem source it's ball on TortoiseSVN's part.
Re: TortoiseSVN icons overlays disapear
Posted: 02 May 2007, 23:26
anon wrote:If I kill the process tsvncache.exe and restart salamander - it's ok again
Instead of killing tsvncache please try to open Windows Explorer and check if overlay icons are displayed there. Please let us know.
Posted: 02 May 2007, 23:49
by cincura.net
Jan Rysavy wrote:Instead of killing tsvncache please try to open Windows Explorer and check if overlay icons are displayed there. Please let us know.
When this happend to me, WinExplorer wasn't working too.
Posted: 03 May 2007, 08:27
by crystalidea
Petr Solin wrote:anon wrote:I'm using the latest version of TortoiseSVN.
TortoiseSVN 1.4.3, Build 8645 - 32 Bit , 2007/02/04 09:40:57
Subversion 1.4.3,
apr 0.9.12
apr-iconv 0.9.7
apr-utils 0.9.12
berkeley db 4.4.20
neon 0.26.3
OpenSSL 0.9.8d 28 Sep 2006
zlib 1.2.3
Windows XP SP2 32bit.
I face the problem on both my work and home computers. I'll try to open explorer next time.
Posted: 06 May 2007, 18:56
by crystalidea
Windows Explorer displays overlays when salamander fails...
Posted: 07 May 2007, 06:10
XPiS, the first post from
anon is from you? If no, could you please try to restart Salamander (do not kill the tsvncache.exe process) when this problem occurs?
Could you please test the
nightly build of Tortoise SVN?
Posted: 07 May 2007, 19:25
by crystalidea
Hello, Jan Rysavy
The first post is mine.
Sorry for my mistake - the windows explorer fails as well. Restarting salamander or explorer doesn't help. Killing tsvncache helps.
I'll try the latest builds.
Tortoise Overlays
Posted: 07 May 2007, 20:24
by Francisj
I have a different slant on this issue. I use multiple Wiondows profies at different clients, but the Tortoise overlays only display under the account where I installed Altap Salamander (they are still visible in Windows Explorer, and I'm using the latest nightly build of Tortoise).
Re: Tortoise Overlays
Posted: 07 May 2007, 20:51
Francisj wrote:I have a different slant on this issue. I use multiple Wiondows profies at different clients, but the Tortoise overlays only display under the account where I installed Altap Salamander (they are still visible in Windows Explorer, and I'm using the latest nightly build of Tortoise).
Hi, it is probably another problem, could you please copy&paste your post to new thread? (
Forum Rules, paragraph 2 and 4)
