Comparing identical files
Posted: 29 Apr 2007, 15:39
by Thomas
I miss the option "comparing identical files" only short message, "files identical". It's not nesassary to open the complete file compare tool when
files are identical.
Posted: 29 Apr 2007, 17:05
by cincura.net
But the File Comparator does the job - it must be opened. If files are identical, you got a message with choose whether to close the window or not. It's (almost) the same you're proposing.
Posted: 29 Apr 2007, 23:43
by thomas
Open a complete window isn't helpful. Which solution would you prefer?
Posted: 02 May 2007, 03:08
by therube
The only "advantage" that I can see, is that it gives you the ability to get to Options | Configuration... :?.
In there, there are some options not accessible from the Ctrl+Shift+C dialog.
In other words, there is no real advantage to it working the way it is.
Posted: 03 May 2007, 11:12
by thomas
It's only a cosmetic effect. I don't like that in the case of identical file,
popup a large blanc window. I think the compare modul can check the
files first for different. When you use the F2 Button, you wouldn't like
popup a complete blanc window in the background.
It's no big thing, only my feeling.
