Comparing identical files
Thomas
Post by Thomas »
I miss the option "comparing identical files" only short message, "files identical". It's not nesassary to open the complete file compare tool when
files are identical.
cincura.net
Post by cincura.net »
But the File Comparator does the job - it must be opened. If files are identical, you got a message with choose whether to close the window or not. It's (almost) the same you're proposing.
Jiri {x2} Cincura
thomas
Post by thomas »
Open a complete window isn't helpful. Which solution would you prefer?
The only "advantage" that I can see, is that it gives you the ability to get to Options | Configuration... :?.
In there, there are some options not accessible from the Ctrl+Shift+C dialog.
In other words, there is no real advantage to it working the way it is.
thomas
Post by thomas »
It's only a cosmetic effect. I don't like that in the case of identical file,
popup a large blanc window. I think the compare modul can check the
files first for different. When you use the F2 Button, you wouldn't like
popup a complete blanc window in the background.
It's no big thing, only my feeling.
