"Check for New Versions" Not working
I would like to see the "Check for New Versions" working again. I haven't seen it work for a couple versions now.
I'd also like to see the capability of Altap being able to initiate an update without user input (silent). That way if Altap finds bugs (enhancements) they can be fixed without requiring an expiration on the program. That would save a lot of time for the user to re-install every time a new release comes out. And it would also resolve all the issues of why the software has had an expiration date on it. Altap could keep all copies up-to-date without people having to download and re-install the new version.
Thank you,
Docfxit
Thank you,
Docfxit
Sorry for having to report this, but it does not work for me in 2.5 final - it already didn't in RC3. Earlier RCs worked fine.Jan Rysavy wrote:The CheckVer plugin is working again.
The plug-in does not seem to connect to the website, there is no activity on the modem line during the check. Afer some seconds, an error message comes up about not having been able to make a connection.
The FTP-client works perfectly.Jan Rysavy wrote:I have another idea: could you connect to our (or other) FTP server using Salamander's FTP client? (ALTAP server address is defined in FTP bookmarks)
This is e.g. the content of the file english.txt in the directory checkver:
SALAMANDER_VERINFO_BEGIN
salamand.exe
Altap Salamander
2.5
www.altap.cz
-Operations Copy, Move, Delete are running at background, the main window is not blocked.
-Transfer speed and time estimation is displayed. You can also set the speed limit.
-Icon overlays are displayed in panels (Offline Files, Tortoise SVN/CVS, etc.).
-20 new plugins (FTP Client, Undelete, Renamer, File Comparator, etc.)
-Support for Windows Vista.
-And much much more. For more information please visit our web site.
SALAMANDER_VERINFO_EOF
OK, so Salamander is really not blocked by some firewall.
Do you use Internet Explorer or some alternate web browser? If you don't use IE, please try to start it and check the "offline" state.
CheckVer plugin (for simplicity) is using standard Windows Internet API to reach our web site. This API is connected to Internet Explorer so the problem may be there.
Interesting, that could be the problem - I use Opera 9.01 and FireFox 2 exclusively.Jan Rysavy wrote:Do you use Internet Explorer or some alternate web browser? If you don't use IE, please try to start it and check the "offline" state.
Yes, that was the problem - IE was not configured properly for http-connections. I use the Proxomitron webfilter, so all browsers need to connect through a local proxy, with the right port definition set. The "Work Offline" state was in fact turned off, so that did not cause the problem. Interesting that the wrong http-proxy settings also affected the ftp-protocoll used by the plug-in.
In any case, Check Version works again - thank you
