During installation of RC3 I got the following error:
"Eroiica Viewer: Creating instance of WMF export filter failed. Unspecified error"
Installation problem: Creating instance of WMF export filter
Re: Installation problem: Creating instance of WMF export filter
Roman2,roman2 wrote:During installation of RC3 I got the following error:
I'd like to ask you for more information needed for troubleshooting.
What version of Windows do you have?
Did you install RC3 to the same folder with RC2?
Do you still get this error when you launch Altap Salamander?
Are you able to view any file in a format supported by Eroiica Viewer, e.g. PDF, MS Word DOC, MS Excel XLS?
-- Jan
Guest
Q: What version of Windows do you have?
Win XP SP2
Q: Did you install RC3 to the same folder with RC2?
Different.
Q: Do you still get this error when you launch Altap Salamander?
No. If I remember correctly, the error happened during the plug-in installation stage.
Q: Are you able to view any file in a format supported by Eroiica Viewer, e.g. PDF, MS Word DOC, MS Excel XLS?
Yes (although, it too often does a poor job at this, but this is a separate issue).
Win XP SP2
Different.
RE: Creating instance of WMF export filter
Eric, I would be very grateful if you could send me a "bug report" from your computer(s), preferably from both XP and Vista.Eric wrote:I got the same error (on XP and Vista).
And it happens also when I start Salamander after installation (not always)
Do the following:
1) start Salamander
2) try to view (using the F3 key) any file supported by Eroiica Viewer plugin, i.e. PDF, RTF or MS Office format (DOC or XLS)
3) by now you have probably received the error and the attempts to view the files failed
4) In Salamander main window menu, go to "Help/Report Bug..."
5) Send me the "Prepared text" to support{at}pictview.com
Thank you!
Re: RE: Creating instance of WMF export filter
I try to reproduce the error.Jan Patera wrote:Eric, I would be very grateful if you could send me a "bug report" from your computer(s), preferably from both XP and Vista.
But give some time (I'm soon away for one week).
Eric
