$(FullPathRight)
skwoz
$(FullPathRight)
Post by skwoz »
I have a simple problem. I do have a difference tool wich takes direkctories as arguments. It cannot swallow directories ending with
"\". If I need to compare "C:\Prgram Files" with "D:\Program Files" and I use customizeed user menu it makes something like:
diff "C:\Prgram Files\" "D:\Program Files\"
How can I omit the "\" at the end of each argument???
Thanx
Frank
th.
Post by th. »
Here's a little VBScript to get rid of the trailing "\":
Set objArgs = WScript.Arguments
Verz1=objArgs(0)
if right(Verz1,1)="\" and right(Verz1,2)<>":\" then Verz1=left(Verz1,len(Verz1)-1)
Verz2=objArgs(1)
if right(Verz2,1)="\" and right(Verz2,2)<>":\" then Verz2=left(Verz2,len(Verz2)-1)
Set sh = WScript.CreateObject("WScript.Shell")
sh.Run "diff """ & Verz1 & """ """ & Verz2 & """"
Save it as e.g. diff.vbs and use it in AS as the user menu command.
Set the path to your compare tool in the last line according to your needs.
Thomas
NICE!
Guest
Post by Guest »
You can replace:
if right(Verz1,1)="\" and right(Verz1,2)<>":\" then and
with:
If Verz1 Like "*[!:]\" Then and
If Verz2 Like "*[!:]\" Then
to make it faster.
You may try to add a dot at the end of the path and forget about the script.
i.e "$(FullPathRight)." to get "D:\Program Files\."
skwoz
Post by skwoz »
Thanx a lot for the dot-tip! Perfect! It works perfectly
