feedback on RC3 fast rename [F2] (delay)
hotdog
Post by hotdog »
hi folks,
I'm currently evaluating RC3 and I just came across this symptom when I press F2 on a file or directory: it takes about half a second to show the new rename dialog. I realize there is some added functionality (skipping the extension, which is VERY welcome btw) but this delay was never noticeable in the previous RC versions of salamander. Ok, I admit this is not a bug, but I wanted to report it because there may be something wrong that is slowing down this function.
btw, RC3 is a big improvement! You did a heck of a job Altap!
I cannot reproduce such behavior...
On my system is this action instant (not measurable).
Does this also happen with system explorer's F2 rename function?
I think that you could have some shell extension problems. Try to check it with http://www.nirsoft.net/utils/shexview.html
jis
Post by jis »
SelfMan wrote:I cannot reproduce such behavior...
The same on my system.
maxovt
Post by maxovt »
Me too.
My deepest apologies for my awful English.
Re: feedback on RC3 fast rename [F2]
hotdog wrote:but this delay was never noticeable in the previous RC versions of salamander
Could you please test RC2 now?
hotdog
Post by hotdog »
just checked it on RC2 and there's no problem :oops:
nevermind, I must have been deceived by the "Rightmark CPU utility" which was running my CPU on "power on-demand" mode, so the overall system performance was very low.
thanx for your prompt replies
So, RC3 works fine now?
cincura.net
Post by cincura.net »
Me too.
Jiri {x2} Cincura
