				configuring SS
				Posted: 12 Dec 2005, 00:05
				by omega
				hi,
Is there a way i can open txt files very fast in SS. Cause notepad is very slow here, taking about 15 sec to open.
Plus how do you configure SS to change an external editor instead of using notepad?
				Re: configuring SS
				Posted: 12 Dec 2005, 00:24
				by areve
				omega wrote:Is there a way i can open txt files very fast in SS. Cause notepad is very slow here, taking about 15 sec to open.
Press
F3
omega wrote:Plus how do you configure SS to change an external editor instead of using notepad?
Option>Configuration>Viewers & Editors>Editors
Create a new file mask *.txt and choose another editor in the Command box.
I use
Crimson Editor, which is fast, free and has many more features than notepad.
				Posted: 12 Dec 2005, 00:36
				by manison
				By default hitting F3 on *.txt files launches the instant internal text viewer.
You can configure external text editor in Options/Configuration/Viewers & Editors/Editors page.
				Posted: 12 Dec 2005, 11:03
				by omega
				I created a new mask *.txt and configured in the command box to choose a different external editor. After saving this configuration i restarted SS but still when i open a txt file Notepad seems to appear instead the other editor.
Any clues?
				Posted: 12 Dec 2005, 11:12
				Could you export your Servant Salamander configuration (Options > Export Configuration), pack it using ZIP archiver, and send it to my email
jan.rysavy@altap.cz ?
				Posted: 12 Dec 2005, 15:01
				by omega
				Guys, it should be F4
 thanks Jan
				Posted: 12 Dec 2005, 15:59
				Options > Configuration > Viewers & Editors:
Viewers -- F3 (View command)
Alternate Viewers -- Alt+F3 (Alternate View command)
Editors -- F4 (Edit command)
There are also handy Ctrl+Shift+F3 (View With command) and Cltr+Shift+F4 (Edit With command) to bypass associations from configuration and force desired viewer or editor.
