hi,
Is there a way i can open txt files very fast in SS. Cause notepad is very slow here, taking about 15 sec to open.
Plus how do you configure SS to change an external editor instead of using notepad?
configuring SS
Re: configuring SS
Press F3omega wrote:Is there a way i can open txt files very fast in SS. Cause notepad is very slow here, taking about 15 sec to open.
Option>Configuration>Viewers & Editors>Editorsomega wrote:Plus how do you configure SS to change an external editor instead of using notepad?
Create a new file mask *.txt and choose another editor in the Command box.
I use Crimson Editor, which is fast, free and has many more features than notepad.
Could you export your Servant Salamander configuration (Options > Export Configuration), pack it using ZIP archiver, and send it to my email jan.rysavy@altap.cz ?
Options > Configuration > Viewers & Editors:
Viewers -- F3 (View command)
Alternate Viewers -- Alt+F3 (Alternate View command)
Editors -- F4 (Edit command)
There are also handy Ctrl+Shift+F3 (View With command) and Cltr+Shift+F4 (Edit With command) to bypass associations from configuration and force desired viewer or editor.
