Full row select in detail view
voidcoder
Post by voidcoder »
Hi Salamanders,
I'm a newly-converted salamander :) my old religion
was Total Commander beginning with its first release.
Well, I'm not yet registered and curretly playing with
the evaluation version. But it is definitely clear for me
after a few days of use that it is exactly what I was
missing these years! Going to buy immediately!
The only uncomfortable (and easy to implement)
thing for me is the missing full row select option in detail
mode since the distance between the columns is quite
huge and it is problematic to visually match say attr
column text for the selected item ...
It would be great if this can be added in the upcoming
2.5 release. Perhaps it is already supported but I was
not able to find it browsing through the options.
Anyway, great and must-have file manager!
You needed only 2 things...
F1 to open help and enter "full row" (without quotes) and enter.
Options > Configuration > Appearance > [x] Full row select
voidcoder
Full row select
Post by voidcoder »
Ops, somehow skipped it when was looking through
the options :) Thank you!
The only thing is that there is no answer from the
sales@altap.cz yet ...
Re: Full row select
voidcoder wrote:The only thing is that there is no answer from the
Could you please send your email again?
voidcoder
repost
Post by voidcoder »
just did it
