Compare Directories - Jump To Selected File(s)
When comparing directories, especially larger directories, at times there will only be a few files "Selected".
Currently, there is no way to determine which files they are - without scrolling through the directory list, physically looking for the Selected files.
Perhaps Compare Directories, could, ... no F3 wouldn't work would it, ... maybe be able to bring up a "Focus" command, such as is available from Find?
ino
Re: Compare Directories - Jump To Selected File(s)
Post by ino »
therube wrote:Currently, there is no way to determine which files they are - without scrolling through the directory list, physically looking for the Selected files.
Acctually I did not realize that function are time built-in the Servant Salamander for long time.
They can be found in the Menu - Edit - Advanced - *
BTW: for quick access to those functions you can add them as icons into your Top or Middle Toolbar.
Just right click the toolbar and select Customize Toolbar and drag and drop in to your toolbar.
Did you know about Alt+Up / Alt+Down which jumps to the next selected item?
No I didn't. But I do now :D!
That is just what I was looking for.
One day I'll come to learn all the nuances of this program.
One day I'll get the time to RTM :lol:.
