Hey!
Download the file
http://tango-project.org/releases/tango ... 7.2.tar.gz
I didn't check all files, but this one
tango-icon-theme-0.7.2.tar.gz\tango-icon-theme-0.7.2\22x22\animations\process-working.png
is displayed fully BLACK!
You can check the correct display using Axialis Icon Workshop or other...
Regards.
PictView 32bit PNG bug
- crystalidea
- crystalidea
Re: PictView 64bit PNG bug
I don't understand why you don't send us direct emails, I have been asking you for about a year.XPiS wrote:http://tango-project.org/releases/tango ... 7.2.tar.gz
The image you are referring to is 64 bit. Just Hit F3 to check.
Alpha-blending of 64bit images is not (yet) supported.
- crystalidea
Sorry, i don't like email. The same 16x16 picture in the archive is displayed OK. Check it.Jan Patera wrote:I have been asking you for about a year.
The "same" 16x16 picture is in 32bit, but the problematic picture is in 64bit. The smaller picture also specifies white as background color.XPiS wrote:The same 16x16 picture in the archive is displayed OK. Check it.
I asumed the problem was with Alpha channel and the background color, because my own program displayed black picture as well (it uses LibPNG library v1.0.1).
EDIT: I just tested 64bit picture with background from PngSuite and LibPNG v1.0.1 in my program works fine, but PictView not. (picture bgyn6a16.png)
