i can search for files on Attribut "last modified" but not "last accessed"
for example
i won´t find files with last access after "date" "time"
Is there a way to do this?
Thanks
Helmut
Find files on attribut "last accessed"
I'm all for it
Would be nice to have this feature in a next version of SS, to make the best filemanager even betterJan Rysavy wrote:Last Access Time and Creation Time are not supported in Panels and Find window (yet).
Snowdear
Re: I'm all for it
Last Access time is NTFS proprietary, is it not? I dont think FAT has such a thing.Snowdear wrote:Would be nice to have this feature in a next version of SS, to make the best filemanager even betterJan Rysavy wrote:Last Access Time and Creation Time are not supported in Panels and Find window (yet).
Snowdear
TBH, I personally disable last access time on my NTFS partitions (it is a small speed improvement).
So if this feature is added can it be an optional one?
Thanks.
Re: Find files on attribut "last accessed"
As I see, it's on the roadmap:Helmut wrote:i can search for files on Attribut "last modified" but not "last accessed" for example i won´t find files with last access after "date" "time"
Custom panel columns (parsers for EXIF, MP3 bitrate, Access Time, etc.)
