Request: Find window > Space always opens in same pane
mailyourmom
Post by mailyourmom »
I like the space key in the Find window very much. It will highlight the file or folder selected in the Find window in the main window. However, it always jumps to the selected file or folder in the last active pane, which is sometimes very annoying, especially when jumping back and forth between the Find window and Servant Salamander's main window and doing some copy/paste actions in between. Could you implement a way to make Servant Salamander always jump to the selected file in either the left or right pane?
Thanks,
Michiel
