Copy a file oldname.txt to another folder with new*.*
The copied file is newname.txt and not as expected newoldname.txt
Bug or feature?
Copy and rename files with *.*
Re: Copy and rename files with *.*
It is the same as in Windows Command Line. So it is windows feature.Anonymous wrote:Copy a file oldname.txt to another folder with new*.*
Bug or feature?
you can use Renamer plugin (from menu Plugins > Renamer > Batch Rename or using CTRL+SHIFT+R hotkey)
Then in the New name field write: "new$(OriginalName)" , check the new names in the Preview part and click Rename
Renamer plugin can be used for more sophisticated renaming, using substrings, dates, counters, regular expressions, and more ...
- More information about Renamer plugin - with example for your case (Adding a prefix to all names)
- Information about Regular Expressions in Renamer Plugin
anyway you can use another wildcard character the question mark "?" which represents one character.Anonymous wrote:Copy a file oldname.txt to another folder with new*.*
Bug or feature?
in your exaple:
oldname.txt using new*.* you get newname.txt
oldname.txt using new???????.* you get newoldname.txt
for more examples see this link http://www.google.com/search?num=100&q= ... tnG=Search
