I would like to point out the different results of case changes in filenames that you get using
Files - Change case - Partially mixed case
on the one hand and
Plugins - Batch Rename - Mixed case
on the other hand. Imagine the following filename:
bachman-turner overdrive (you ain't seen nothing yet).mp3
Files - Change case - Partially mixed case gives you:
Bachman-turner Overdrive (you Ain't Seen Nothing Yet).mp3
Plugins - Batch Rename - Mixed case gives you
Bachman-Turner Overdrive (You Ain'T Seen Nothing Yet).mp3
Altap has already pointed out that the bevaviour of Batch Rename is by design (see http://forum.altap.cz/viewtopic.php?t=755), but I think that this inconsistency might be unwanted. The best result of these change case - options would imho be
Bachman-Turner Overdrive (You Ain't Seen Nothing Yet).mp3
Best wishes
Consistent results of case changes in filenames
Klettermaxe
