The sorting works only ascending, but often a descending order is needed.
Also the sorting restarts on each directory. This is ok by default, but it would be great if you can apply the sorting to all found items.
Find Dialog - Sorting Items
Re: Find Dialog - Sorting Items
Could you please clarify this? (Sorting is applied to all items...)binor wrote:Also the sorting restarts on each directory. This is ok by default, but it would be great if you can apply the sorting to all found items.
