When removing an USB stick while it is active in one of the panes, first the usual message appears ('Error Changing Directory'). If confirmed with OK, the Configuration dialog opens, which seems strange (like a fault behaviour) to me.
Franz
Removing USB stick
It is a feature, not a bug
Please look at error message, the path is specified there. This path is not accessible on your computer so Salamander opens configuration dialog box and wrong path is selected. Then you can enter valid path.
From Help:
If path in panel is inaccessible, go to
Specify the path where to go if path in panel becomes inaccessible (you remove medium from CD/DVD drive, network is not available, USB stick is unplugged, etc.).
From Help:
