Multimedia Viewer does not show the sampling rate (Frequency) correct on all versions of mp3 files.
- MPEG1.0 Layer3 is correct
- MPEG2.0 Layer3: Frequency is shown false (doubled)
- MPEG2.5 Layer3: Frequency is shown false (4-fold)
QuickTime Player does show it correct as well as WinAmp does.
Ping me if you need sample files.
Franz
Error in Multimedia Viewer (2.5RC2)
Hello Franz,
Could you please put samples to some web site (or use http://www.uschovna.cz/en/ ) and send me email? Thank you.
Re: Error in Multimedia Viewer (2.5RC2)
The problem has been solved for the next version of Altap Salamander (2.52).McLion wrote:Multimedia Viewer does not show the sampling rate (Frequency) correct on all versions of mp3 files.
