The option for "Wait until all other Copy/Move operations are finished" is greyed out, and I have no idea how to make it clickable. Does this mean I can't queue files to copy with SS v2.5 RC1?
And if this software can't do it, does anyone know of ANY software that can make a queue of files to copy and then do it in one operation?
Thanks...
Is it possible to queue files when you copy or not? :)
PCF
Oooops - ignore that one... it worked actually
But still I would like more features to this. I'll make a post in the request-forum.
Sorry for f**king up.
Guest
Hitman
PCF wrote:
You can do it with Total CommanderAnd if this software can't do it, does anyone know of ANY software that can make a queue of files to copy and then do it in one operation?
Servant Salamander can queue file copy/move operations. But you can queue other file operations only when at least one other copy/move operation is already running. If you want to queue many operations, start the first copy/move operation; click on [Pause] button and then add other operations to the queue (using the now enabled checkbox). Finally click [Resume] the start the whole queue.
BTW: For checking the checkbox you can use Alt+W hotkey even without opening the Options part of the copy/move dialog
