Function Keys
Function Keys
Just tried the demo for Salamander 2.5 RC1, and my function keys do not work. The buttons that they map to do work. Didn't experience this with Salamander 2.0 or 1.5.
Re: Function Keys
I am not quite sure I understand what you are talking about.
Never heard abou problems with function keys. Could you please make sure there is no program active which hooks the keyboard and thus might interfere (i.e no program which defines global hotkeys).
Is this said about the Bottom Toolbar?Dekaritae wrote:The buttons that they map to do work.
Re: Function Keys
Er yes, that's correct. The buttons on the bottom toolbar (Copy, Move, etc) work correctly, but the equivalent function keys do not. Both work correctly with previous versions of Salamander, and I have checked to see if those keys are being trapped by any applications.SvA wrote:I am not quite sure I understand what you are talking about.
I do still have 2.0 installed. With both running, the function key behaviour is as described; 2.0 works as expected, 2.5 does not.Jan Rysavy wrote:Do you still have Salamander 1.52 or 2.0 installed? Could you try it in the same time as 2.5?
Apologies, it seems the problem is my concern. The application I use for window skinning, ShellWM, doesn't recognize your new dialog boxes. With it's skinning disabled, the function keys work correctly in 2.5.
