The internal Viewer (F3) does not show the Euro Symbol (€).
I have it set to Auto-Select and it selects to not convert. However, none of the pages available does show the € symbol.
Franz
Viewer Codepages
You must have patched older MS Windows (fonts) to be able to display euro symbol and change internal viewer font (menu Option-configuratio-viewers&editors-internal viewer-font) to one of font MS patched. E.g.: Courier new.
Then (when "not convert" selected) is internal viewer able to display ascii code 128 (hex 80) as euro symbol (tested on XP pro CZ localized version).
