Hello Altap!
Wouldn't it be nice to release the free version of Salamander for U3-standards? Or for customers the actual version?
http://www.u3.com/
Greetings
Udo
Salamander for U3-Standard
Tomas Kopal
Showens
U3 compatibility
I've just now discovered U3 (and also it became affordable for me!), and I would love to have SS run on startup, just as I do on my desktop(s). I've tried fiddling with the XML files in \System\Apps, but when I try to specify that it launch on startup, the launcher complains.Tomas Kopal wrote:Well, for the start, Salamander should be able to run without installation (already possible) and without using registry (planned). Then it should be easy to run it from any USB stick, not only from U3, IMHO.
There's something specific in the .u3p format that the U3 environment likes. Some .u3p files actually launch .exe's, Maxthon for example.
SS is my Swiss Army Knife! I use it all day long, and I'd love to be able to take it on troubleshooting missions in the field.
There is an SDK and some docs. I have not yet looked at them, so I don't know what's involved with creating a U3-compatible version. I hope it's simple, such as creating a stub that simply launches salamand.exe
