integrate MP3 Directory Player
It would be greatly if a directory more player like 1by1 http://mpesch3.de1.cc/1by1.html being integrated in Servant Salamander.
Just add the program to your user menu or as a (alternative) viewer and you get (mostly) what you want. Note however, that as a viewer you need to enter the folder. Selecting it from the parent folder will not work as desired.
Turning Servant Salamander into an all-in-one device suitable for every purpose is not desirable. We do not need yet another bloatware, but a lean tool, well fit for it's purpose, which in Salamander's case is file management.
Once the plugin SDK is out, maybe someone will crate such a player as an optional plugin.
Re: integrate MP3 Directory Player
Why integrate such a thing? Take Winamp Lite, Right mouse click on folder -> Play in WinampHyperman wrote:It would be greatly if a directory more player like 1by1 http://mpesch3.de1.cc/1by1.html being integrated in Servant Salamander.
A file manager doesn't need playing mp3-files, keep SS lean and fast! Werner
That's itSvA wrote:Just add the program to your user menu or as a (alternative) viewer and you get (mostly) what you want. Note however, that as a viewer you need to enter the folder. Selecting it from the parent folder will not work as desired.
Kind regards, KNUT
