when choosing long file name show full name,add skins option
Guest
Post by Guest »
when choosing / standing on a long file name it shows it like this
"Long file name..." its preaty annoying...
becase if i have "long file name 1.test" , "long file name 2.test"
i dont know which one is the one i need when i stand on it if im not using the information line
skin option are missing... (u can choose your own skin, change icons, make your own skins and upload them so everyone can enjoy it)
another thing is that you canot add text to the toolbar menu...
or make the buttuns bigger (just like in explorer)
when right click in the middle of a pane add options
arange icons by
name
type
all the menu options of course
view..
icons
detailed
all the others also :)
add the option to costumise special folders...
for example i wanne watch most of the folders as icons
but in my pictures i want to c thumbnails
and its preaty anoying to change it all the time espacialy when u dont
have it on right click
and you have to move all the way for the bar buttun
cheers
Re: when choosing long file name show full name,add skins option
Hi anonymous guest,
Please, before posting, read the forum rules (in particular item 4.) and the roadmap.
Anonymous wrote:when choosing / standing on a long file name it shows it like this
Use CTRL-N to switch smart colum with (which reduces need for scrolling to see other colums) and fit longes mode.
You know about the hotkeys to switch panel views (ALT+2..9,0)?
