Word, Excel, PDF viewers
lenw
Post by lenw »
Having been deeply involved with the evolvement of FMEDIT2001 ( take a look) I respectfully suggest you consider any or all of the following:
CALCULATOR
ABILITY TO READ WORD DOCUMENTS
ABILITY TO READ EXCEL DOCUMENTS
ABILITY TO READ PDF DOCUMENTS :?:
When you install FULL version of Servant Salamander 2.5 RC1, there is Eroiica Viewer plugin available. To display DOC/XLS/PDF document, focus it in Servant Salamander panel and press the F3 key (Files > View command).
All supported formats: http://www.altap.cz/salam_en/compare.html
(section Integrated Viewers)
