Save FTP Bookmarks
Save FTP Bookmarks
Today I had an issue with FTP Bookmarks not propagating to new instances of Servant Salamander.
I therefore asked myself when Salamander reads in the bookmarks and when they are saved.
Could you please give some detail on this. Moreover I'd like to know whether Options | Save Configuration from Salamander's main menu will include plugin settings and whether plugins honour the general setting 'Save configuration on exit' on plugin unload and Salamander exit.
Furthermore, is it possible to make Bookmarks work just the same as they do in any internet (www) browser I know?
Plugin configuration is loaded when plugin is loaded (first use), you can check Load/Unload status at Plugins > Plugins Manager.
When plugin is unloaded, the configuration is saved.
Options > Save Configuration will include only Loaded plugins (unloaded plugins are already saved).
