pedump.c
crystalidea
pedump.c
Post by crystalidea »
It seems that you're using pedump source for your Portable Executable viewer. Why don't you place the author of pedump in the about dialog together with Henry Spencer?
You are wrong. The PE Viewer is based on this document:
The Portable Executable File Format from Top to Bottom
Randy Kath
Microsoft Developer Network Technology Group
http://jonjon.off.co.il/rec-sec/The_Por ... Bottom.txt
Please look at Forum Rules (point 5).
crystalidea
Well, ok no problem. I've just wondered. What about the rules? Did I violate smth?
XPiS wrote:What about the rules? Did I violate smth?
5. Use subjects explaining the topic. Examples of bad subjects: "Help!", "I have a problem", "I found a bug", "A few requests". Examples of correct subjects: "Automatic refresh is not working on network drive", "Servant Salamander main window is always on top of all others.", etc.
