Find: Store searched filetrees for faster re-search
DerDu
Post by DerDu »
Hi again...
What i mean is some sort of index-database in which the Filesystemtree is prestored so find could be mutch faster.
I'am doing this kind of thing at my Fileserver-Raidsystem with hundred thousands of files for some time now and it rocks...
i dont have to wait minutes and minutes anymore to find a file but only a few seconds.
true... it only works this way because of a complete backgroundscan of all drives and the information is stored in a sql database, but maybe some indexing in SS would be nice anyway.
sry 4 the bad explanation style
EDIT
ok because my english is very plain i did some shema for better understanding
ty&cya-DD-sorry4poorEN
DerDu
Post by DerDu »
Another way to do realy quick searching:
- as first step - scan the MFT for filenames
- 2nd - check for correct information
- 3rd - do other "Find" routines with the found files
(this is the method used in std. Windows searchpanel)
DerDu wrote:(this is the method used in std. Windows searchpanel)
Are you sure the direct MFT access is used at Windows > Search > For Files or Folders? It looks like classic directory tree enumeration... (W95, NT, W2K, XP).
DerDu
Post by DerDu »
ah.. sorry.. :oops: got mistaken there .. it doesnt (only indexing) .. but programs like "O&O Defrag" (does MFT scan for pre-analysis) do.
EDIT
...and your "Undelete"-Plugin too.
