Enable command line inside archives and/or ftp/scp sites.
eblis
Post by eblis »
Is it possible to enable the command line inside archives/ftp sites/scp sites ? Sometimes you may want (or need) to run a command by hand. It could be considered an advanced setting and the user must realise that it might break the connection.
To do this, Salamander would need to stop setting the working dir to the focused pannel's dir.
That's may be the better solution than to disable it.
Are there more issues which justify disabeling it (appart from hotkeys which copy path information from the file pane to the command line, which might not be useful to any program under these circumstances)?
