INFO: PictView plugin: German version available for download
Forum rules
German version of the PictView plugin is now available for download at
http://www.pictview.com/salamander
Please feel free to post any comments and/or bug reports either to support[at]pictview.com or to this forum or to the translator Thomas Woelk (his email address is in the About box).
Thomas's nick here in the forums is beta.
Please report also any misaligned, partially-visible or untranslated text and also feel free to let us know your general feeling about the translation.
Thomas has done a great job, he has spent a lot of time by choosing proper German equivalents, but, not only because I don't speak German , I'd like to hear opinions from other native German speakers.
Thomas, thank you! You reward is prepared for you
--- Jan Patera
P.S. Unless mailing directly to Thomas, please use English (or Czech or Russian) - I don't speak German....
--- Jan Patera
Wenn jemand mal über die deutsche Version gucken könnte, so wäre das echt nett.
Ich habe (leider) mit dem neuen Release ein paar Sachen schon gefunden, die ich am Wochenende beheben werde (Rechtschreibfehler, Texte der Statusbar, Metakeys). Jan wird sicherlich dann umgehend eine neue Version bereitstellen.
[Moderator: off topic post moved to Problems and Troubleshooting->Error calling PVW32Cnv.DLL with PNG file]
@Jan Patera: Why don't you translate the word "Translation" (german: Übersetzung) ?
Hilfe>Über PictView...
Other phrases you forgot:
* "Client area of foreground window"
my suggestion: "Arbeitsbereich des Fensters im Vordergrund"
if it doesn't fit in: "Fenster im Vordergrund (ohne Rahmen)"
* "Assign some available hot key"
my suggestion: Weisen Sie einen verfügbaren Hotkey zu.
* "This function will update the thumbnail in Exif section of the image file(s). The rest of the file will not be modified. Proceed? [Yes] [No]"
my suggestion:
Diese Funktion verändert die Thumbs (kleine Vorschaubilder) im Exif-Bereich der Bilddateien. Möchten Sie fortsetzen? [Ja] [Nein]
failures I found:
missing s in "Diese Datei existiert bereits.
Wollen Sie die Datei ersetzen?"
Anyway, big THANX 2 Thomas Wölk. ;o)
my suggestion:
failures I found:
(o.O) -(@.@)- (/o.O\) ,,,`Q´,,, {~.~} (^.^)
Translation ť Übersetzung: done
Wo wird das angezeigt?
my suggestion: [...]
Die Frage ist, was der Servant Salamander in seiner deutschen Version verwendet? Ich habe das ganz bewußt unübersetzt gelassen. Verwendet man Miniaturansicht, Vorschaubilder, Thumbnail, ...?
Plugins>PictView>Bildschirm fotografieren...
Erscheint nur wenn Screen Capture versehentlich zweimal gestartet wird und bei beiden Instanzen der selbe Hotkey verwendet wird. Ich selbst bin nur durch Zufall/eigeneDummheit drauf gestoßen.
New German version available for download at http://www.pictview.com/salamander
Thomas, thank you again!
"Mit gedrückter linker Maustaste Bild verschieben" ist zwar deutlicher, aber auch wesentlich länger...beta wrote:Hat jemand einen Vorschlag für die Statustexte. "Klicken und Ziehen" klingt irgendwie Wischiwaschi.
Kind regards, KNUT
Klick' & Zieh'beta wrote:Hat jemand einen Vorschlag für die Statustexte. "Klicken und Ziehen" klingt irgendwie Wischiwaschi.
Schöne Übersetzung Hier mein Senf.
PictView 1.99 b10
Warum nicht einfach Vergrößern und Verkleinern ?Ansicht | Einzoomen
Ansicht | Auszoomen
Dasselbe bei (-)% und (+)%
In Salamanders Dateiliste/Suchdialog markieren/demarkierenIn Dateiliste/Suchdialog markieren/demarkieren
Damit weiß man besser was damit gemeint ist.
Klicken + ziehen um das Bild zu verschieben.Click and drag to scroll image in desired direction.
Klick vergrößert. Shift+Klick verkleinert. Klick+Zieh für Auswahl. Leertaste zum verschieben.Click image to zoom in; click and drag to marquee zoom. Space for marquee drag
Klick+Zieh für Auswahl. Shift+Zieh Quadrat. Leertaste zum verschieben.Draw rectangular selection outline. Shift and Space for additional options.
HTH
Stefan
Pleased user since v1.52 - Licence# 0306-0046-01
Stimme ich mit Dir überein. Ich werde das am Wochenende ändern. Jan hat noch diverse Sachen tiefer gelegt und die muss Beta noch einarbeiten.Warum nicht einfach Vergrößern und Verkleinern ?
Hatte ich erst. Das Menü wird zu bereit. Ausserdem in welcher Dateiliste soll sonst markiert/demarkiert werden?In Salamanders Dateiliste/Suchdialog markieren/demarkieren
Aber hallo! Danke!HTH
The plugin has a lot of additional functionality over that freeware program which has not been updated for a couple of years. And of course the plugin has neat integration with Servant Salamander.bback wrote:I can't understand why I have to pay for a plugin that is based on a freeware program...
BTW, why do people pay for services if they can do most tasks manually at home?
