[Moderator: Moved from General Discussion->INFO: PictView plugin: German version available for download]
Jan,
I received this error when i tried to view a png file inside a zip file using SS and pictview.
Error calling PVW32Cnv.DLL
Data reading error - the file is damaged!
If i open the zipfile using winzip and drag the png file to another viewer e.g. irfanview i can view it without a problem. Also extracted the file to see if i can view it with your pictview but the result is the same.
Other png files didn't get this error so i guess the dll file needs to be fixed.
Error calling PVW32Cnv.DLL with PNG file
Re: pictiew dll error
Dear guest,guest wrote:Jan,
could you please send me the PNG file to support[at]pictview.com?
If you prefer to stay anonymous, you may use http://www.yousendit.com.
Please start new threads for new topics - this your bug report is irrelevant to German translation. I didn't start it either (and also violated the rule) to avoid losing contact with you....
RE: Error calling PVW32Cnv.DLL with PNG file
Fixed. English and German versions available for download at http://www.pictview.com/salamander
The PiNG file is absolutely correct. There is a speed optimization in PictView which could turn into a bug under rare circumstances. These circumstances are now detected and bug avoided. Thanks again for the PiNG file!Guest wrote:Thanks for the update, so what was the problem with the library file?
Guest
This bug is fixed in Servant Salamander 2.5 Beta 11. This is English only.Anonymous wrote:The only update available is for German. Can I safely install this on an English OS, or will it affect my menus, etc.?
If you install German Pictview for Servant Salamander 2.5 Beta 11, you will have German menus, message boxes, tooltips etc. in PictView in German.
Previous (German & English) updates for Servant Salamander 2.5 Beta 10a are no longer available because this version will not function after today midnight.
