I'd really like to see Salamander integrated into Autorun. Say if I plug a USB memory stick in, having one of the options as 'open in tab in salamander' would be great. Another option (though less ideal), that would be nice would be to open another instance of Salamander viewing the drive letter that just appeared.
Also, thanks for making one of the few pieces of shareware I could not get by without.
Autorun integration
In the attached archive you find some files to enable Salamander in Autoplay.
AS_autoplay.reg in combination with ASstart.vbs creates an Autoplay entry that opens the drive in the active panel of Salamander. If Salamander is not running it will be started and the drive will be opened in the left panel.
Alternatively, AS_autoplay_new.reg creates an Autoplay entry that simply starts Salamander with the drive opened in the left panel.
You may have to change the path names in the files according to your system.
- ASautoplay.zip
- Add Salamander to AutoPlay
- (1.54 KiB) Downloaded 1116 times
@lanux128] Tua culpa. Didn't you mean to link to http://www.autohotkey.com/forum/viewtopic.php?t=27218?
