All of a sudden, when I want to change a filename (or copy it to clipboard) and I use "F2" only the whole filename is selected, not the extension.
It used to be the entire string (filename + extension).
Is this a new feature? Can I switch it off?
Changing filename
You can turn it off using Options > Configuration > General > Select whole name (including extension) in Quick Rename.
More information about this change: http://forum.altap.cz/viewtopic.php?t=1964
