Sorry to report this so late in the cycle.
I customarily have the "Open files with salopen.exe" option in the General page enabled. With RC3 and that option enabled, double-clicking a file shows a short hour glass, then nothing more.
Disabling "Open files with salopen.exe" restores proper behavior.
XP SP2
RC3 SalOpen Problem
RC3 now displays an endlessly looping memory address alert when attempting close. I have to use Taskmanager to purge the message
It's possible I have a system problem not related to Salamander. Will keep you informed!
Mouse-centric, Registered
Further update...
I ended up having to do the following to fix the issue:
Uninstall all versions of Salamander
Remove their folders (I saved config.reg and keys elsewhere)
Delete all references in Registry (lots and lots of those!)
Reboot
Install RC3
Start RC3
>Salamander instantly exits but no error alert
Restart RC3
>Salamander starts normally in default mode
Exit Salamander
>Memory error, need Task Manager to purge Salamander
Copy saved (RC3) config.reg (and keys) into Salamander folder(s)
Start Salamander
Rename config.reg
Save Config
Exit Salamander
>No error
Now Salamander behavior is back to normal. (Whew!)
Reboot
Install RC3
Start RC3
Restart RC3
Exit Salamander
Start Salamander
Rename config.reg
Save Config
Exit Salamander
>No error
