Hello,
I noticed an "annoying" change in RC3: when filter is enabled, the first focused field is the radio button.
In RC2 it was the text box, allowing to directly type the filter after having pressed Ctrl+F12.
Or maybe that this was previously considered as a "bug"?
Focused field in filter dialog
Petr, I don't understand why you'd call this a bug. If no filter is active and you call up this dialog, the most obvious thing you will want to do is to set the filter.
You might consider to change the radio control to 'Use filter' by default in this situation and, in any case activate it on any key press or mouse click which does not move focus away from the edit box (i.e. any cursor moves or a click into the input field (for mouse clicks even when it transfers focus to the field, key presses only if it had it before already).
