Right-Click menu problem
roger wrote:This does not make any difference here (W2000SP4), still no action.
When you switch the active panel using the Tab key and open context menu using Shift+F10, could you reproduce the problem too? (I am trying to isolate the problem.)
roger
Post by roger »
Jan Rysavy wrote:When you switch the active panel using the Tab key and open context menu using Shift+F10, could you reproduce the problem too? (I am trying to isolate the problem.)
This seems to work fine. Tested it three times.
This bug will be fixed in the SS 2.5 beta 11, thanks to Roger for testing a special build of Servant Salamander!
Note: To reproduce this problem, you must focus the UpDir item in the active panel and then right-click some file in the inactive panel. Then choose the Delete command from context menu... and nothing happen.
